Gas struts for 80's Fleet?
j_f
Feb 1, 2023
42
Hello All,
I'm looking into installing lift- assist struts on my 80's Fleet. I've read/skimmed the epic thread on the subject, but I can't find a write-up of someone adding these to an older camper like mine with the shorter canvas section. My questions:
1) Should I use shorter struts than the 30-inch most folks are using? If so, what length?
2) If I use the 30 inch ones, is it okay if they just don't reach full-ish extension?
3) What else do I need to know? Quirks/issues?
Thanks in advance!
Did you read the last page of this post?
It has a video of a install that might help. For your camper you'll need to make some measurements for your distance needed on the structs. I ordered the hardware kit from FWC.
  • Like
Reactions: j_f
