Well gfi's trip when the current going out the black is different than what the white is returning. Since it is otherwise working you have current leaking somewhere in you extension cord/ camper. Could be in a fixture, screw through a wire, etc. I was hoping it was just a breaker box mixup which would have been a quick fix.
Did you use a test light like Stan mentioned on your outlet just to double check?
