Had a Qlift done on my Ford Transit
billharr
Jun 30, 2009
2,828
Stockton CA
I did the Q-Lift. 2" is not a lot but every inch helps the way I camp. Next set of tires will add another inch. Yes I looked at Van Compass but the CV joints already have a big bend without adding 2 more inches. Drives fine and the only time I notice the 2 inches is stepping in and out of the van. Lift done by Field Vans in Fresno CA. Workmanship looks good.
When you size up the tires, which ones are you considering? I’ve got a Q-lift schedule on a mid roof Transit conversion, still considering which tires to go with.
215/85/16, I have dualies on the back and need to have some space between the duals. They will give me another inch of lift.
TGK- if you've not already done so, you might check fordtransitusaforum.com and do some searches for larger tires to see other user experiences with those.
I went a bit larger than stock on my Transit. It's a 2019 mid-roof 148" with the Quigley 4x4 option (which includes a 2" body lift)
I went with LT 245/70 R16 E-rated Cooper Discoverer AT3 tires. I know some go larger but I was also seeing posts at the time about having to modify wheel openings or that the spare doesn't fit into its storage area under the floor. I see some compensate by deflating the spare and/or use ratchet straps to keep the spare in place even though it doesn't fit fully into the storage area. There are also discussions about whether it's a problem to mix sizes (i.e., use a stock-size spare when the other three tires are larger), especially on vans with limited-slip rear differential or AWD.
My first set of those Coopers lasted 54K. At that point they could still pass inspection but were getting loud. I had them replaced just before a long trip last summer. I have about 13K miles on the new set.
The larger tire means the speedometer reads low by about 8 miles per hour (according to my GPS).
Thanks for the input. I am familiar with the Ford Transit USA forum and have been spending time there as well. I had a FWC for 20 years, which is how I got hooked up with this forum.
