Hawk maintenance schedule?
Karlton
Jun 19, 2017
173
Southern Idaho
Hi all - I wanted to check in and see what you all do for maintenance over time. My 2017 Hawk has been great except for a door hinge seizing, which required the door to be removed and a new hinge installed. I'm still running the original batteries and I plan on a battery upgrade in 2025. In addition to addressing issues, is there anything else that y'all do for a 'scheduled service' like on your truck? I clean and treat the vinyl several times per year and check the seals around the vents and the roof. I'd appreciate any tips as I hit 7 years with my Hawk, which is unbelievable.
Cheers
It kind of depends on your environment, but refrigerator exterior vent and condenser coil/plate cleanliness should be checked.
Do a detailed check of the turnbuckle attachment fittings on the camper and on your truck to make sure nothing is getting loose or cracking.
Clean the screens on your roof fans/vents. Mine had a surprising amount of lint after 3 years.
