Hello, I am currently in the process of building out my fleet shell. Hot water is something I would love to have.
From my understanding FWC currently uses an "Attwood/Dometic" 6 Gallon in tank water heater.
Overland X uses the tankless "Truma" brand.
My research has kinda shown me pros and cons to both. I am trying to find some more direct advice. I was originally intrigued by the tanked heaters. Thinking it would heat up, hold temp for longer, and I would be able to hold more water.(Fill it when i fill my fresh water tank). They both run off propane and use 12 volt to ignite. I plan on using a 12-16 gallon fresh water tank. I also planned on plumbing in an out door shower. I laid out some parts tonight and the hot water should fit right under my sink.
Options right now are:
Suburban 4 or 6 Gallon Tank Water Heater
Attwood / Dometic 6 Gallon Water heater
Fogatti Tankless Water Heater
Thanks for any input, heres a few pics.
