How do you re-center a pop-up if it shifts during a trip?
h2opup
Apr 18, 2024
64
Oregon Coast
The jack legs have been moved and left at home. So how do I re-center my ATC if it shifts in the bed when I am out on a trip?
I have about 1/2" clearance on either side at the tailgate. I bought from McMaster-Carr hardware, clevis to clevis turnbuckles. I have found that if it is too close on one side, I loosen that side's turn buckle just enough to be an able to rattle it slightly. Drive down a rough road and the jostling pulls it over to the tight side.... it can't go far ! Next day I find the road did my heavy work and I re-tighten.
Clever!
Thanks buckland. Good hack to know about if caught out on the road with this issue.
As long as the turnbuckles are tight I wait until I get home.
Waiting to get back home is my likely choice, too, but what if you are out on a long trip?
My biggest concern to a on-the-road load shift is the drain spigot on the fresh water tank. It was installed with an extremely small amount of clearance -- you can barely twizzle the value lever to open/close the spigot. I mentioned this to Marty at time of delivery -- he twizzled it to show me the operation and he could barely fit his fingers in to get it done. His reply was that this was the same location as the one on his RAM (not the most satisfying answer).
A load shift of 1/2" is going to make it impossible to open the spigot. A shift to the driver's side of 3/4" or more will likely snap that spigot right off. Not to mention this is really threading the needle when loading/unloading the camper onto the truck.
I'm confident that ATC would address this (somehow) in person, but I live many hours away.
Any advice on a self-fix aka taking apart the interior to get at the water tank and moving the value or otherwise adapting the spigot to remedy this problem before it breaks and becomes a much bigger headache?
For the camper not shifting, get the camper placement where you like it. Then make a frame that fills the empty gaps between the camper and truck bed. This will limit the movement and help protect the drain spigot.
