Hello,
I just attached my old school Yakima towers to the roof of my Eagle. I used the Yakima Bolt Top Loader which is a metal plate with 2 carriage bolts per plate. I used the 2 existing screw holes that attached the roof to the frame as a guide. I drilled all 8 holes with a 5/16" metal drill bit without any mistakes!! The frame is 1" wide and 1 1/2" deep. I purchased 8 galvanized carriage bolts to make up for the shorter bolts supplied. I didn`t trust the washers that came with the package so, I used 1"x 1/8" x 9" steel inside the camper. One would think that is probably over kill but I wanted to spread out the load along the frame. Okay, I have a 15lb road bike, a 26lb mtn bike and the Skybox is approximately 38lbs empty........Is this too much weight for traveling down the highway at 65mph? Or, am I a knucklehead for trying???? Please chime in, all opinions are appreciated!
Thanks,
Thanks,
