CoreyTrevor
I searched a lot but didn't find much info on my topic. I want to insulate as much of the camper as I can. I know there will always be parts of the camper that lose a lot of heat, but I think if I can do things in the areas where it's feasible all the little things will add up to a noticeable difference.
I'm going to use EPS under the floor, inside my 2x6 riser platform, because it's cheap, light, and I can keep it dry. Does anyone have advice on what to use on the rest of the exterior plywood? It needs to be able to get wet and not absorb water. Either that or I need to cover or paint it to keep it dry. It would also be great if it didn't cost a fortune
Thanks for any help!
