How to reduce weight of an Alaskan?
LiveLifeNow
Aug 16, 2016
62
I presently own an FWC Hawk and am thinking of ordering a new 8.0 or 8.5 Alaskan Camper.
I like the design, but the weight, in contrast to an FWC, is alarming. Is there a way the manufacturer can be asked to reduce its weight during the construction process? I want the loaded rig to be within the GVWR, and if possible I would like to avoid having to buy a 1-ton truck to carry the rig.
If you have a 1/2 ton, that won't be a good idea. I did carry an 8' NCO in my F-150 with no suspension issues, but the smaller V8 engine wasn't happy going up I-80 into the Sierras with the loaded camper towing a small 11' aluminum boat on a trailer. Now I have an F-250 3/4 ton with a 460 gasser in it and the truck hardly knows the 8' C/O is there!
If you have a 3/4 ton truck and can find the VIN tag and have the GVWR as well as what each axle is rated fo for YOUR particular outfitted truck since things like extended cabs, 4x4, lon beds will effect those figures so you have to check YOUR truck!
Do some homework and then get Brian to give you some input.
I'm seeing the dry weight of a FWC Hawk ( 6.5 regular bed) @ 1100lb, Alaskan at @1400lb. Not a heck of a lot of difference. If your vehicle is a newer 1/2 ton your paylout could be between 1400 - 2300, but like mentioned above , your truck probably will not like it..Move up to a 250 and your payload tops out at around 3500lb.
To pay the added expense of having things removed from an Alaskan is working backwards in my mind.
Good luck
G Vavra
Kinda like asking how to transport a huge load of cargo by air....you can either get a bigger airplane or carry less cargo. Since chopping up the Alaskan or leaving all your camping gear at home isn't possible, you probably need to go with the bigger truck. In this case, a 3/4 ton truck will be needed to SAFELY carry that Alaskan camper in my estimation.
Nobody ever complained that their truck could carry MORE weight than what they rolled out one morning fully loaded with passengers, food, supplies, camping gear, etc. However, a pretty fair amount of the WTW traffic relates to how to carry MORE weight (camper and all that stuff) when the truck suspension is sagging and a trip over the scales tells you that you have seriously overloaded the rear axle.
Post what the VIN tag weight maximums for front, rear, both axles and that will tell what you are up against.
I bet your wallet knows that 460 is there-- holy housecats!
Good advice you give, all humor aside.
Wandering Sagebrush said:
That’s a conversation you should have with Bryan Wheat or Rick Baumgartner. Give the factory a shout.
^ this. They have a well deserved reputation for helpful communication.
I know they did build to desired length and had flexibility with interior build out. Maybe a shell ? tho, might need some sort of interior for structure.
Yup...even though the F-250 hardly knows the Alaskan 8' CO is mounted on it, that extends to the gas mileage as well....about a whopping 9 MPG unless I slow down to 55 or so and are not going into a severe headwind all the time.
