How to unscrew these square hole nuts?
pollux
Apr 21, 2017
169
Los Angeles
FWC campers has a lot of these uncommon nuts inside with 1/8 inch square holes all over.
i cannot unscrew these nuts with hex keys to do repair or changing parts.
can someone tell me what kind of key i can use to unscrew them? thanks
Looks like a deck screw bit would do the job. A set is under $10, and should cover your needs. I believe they’re called Robinson bits.
I purchased a screw driver at Menards back in 2014. Most places carry them. JD
i ordered from Amazon.
GreatNeck CRO2 Robertson #2 Square Tip Screwdriver | Must Have for Repairing Anything Using Square-Head Screws, Common Around the House, in Campers, on Toys, and in Cars
Thank you all!
Most lumber supply stores should have bins of all these type of bits and Star bits. I usually grab a few every other time in the store since they can wear out quickly.
