Ntsqd, All of the campers have telescoping beds, it is no big deal.
Boonie, Here is what I do and I suspect that you will do the same, although you will have more latitude with your pass through design. My gear...backpack, fishing stuff and hunting gear is stored on the floor for travel. I keep everything low so that I can still use my rear view mirror in the cab. After I pop up, all the gear goes on the un-extended bed like an attic leaving the floor area open. I usually sleep "downstairs" on the couch bed since 95% of the time I am alone. If not, the gear gets stowed inside the truck or at the end of the couch for sleeping "upstairs". Not a major issue, and I can tell you will not be carrying tons of stuff to move about. Plus you have easier access to the cab.
More thoughts on your telescoping design: I think the slide out section on my mid 90"s FWC Ranger II is only 1/2" and not 3/4" since one mattress is 2" and the other mattress is 1 1/2" thick so that would save about 1/3 of the weight of that piece of plywood. A bonus to your design is that the foam in both mattress can be the same thickness. One thing to check for is what your maximum thickness can be and still be able to close the top. Measuring from the "C" channel , mine is no more than 5". Bed board 3/4", slide out 1/2", thick mattress 2" and thin mattress 1 1/2". Virtually anything left on the bed and my top will not close properly. It is a very snug fit on my model. If the same bodes true for you, then your mattress will be 1 1/2" to 1 3/4" thick. Not real comfortable, but doable with the right combination of foams. something to consider.
cwd
cwd
