dennis 221
- Joined
- Oct 11, 2019
- Messages
- 401
After removing it,when u reinstall strainer do u lube the rubber gasket? If so with what,Vaseline ect. Also where can I purchase new rubber gaskets for it.
Food grade silicon grease might be the best, but Vasoline is often used, too. Assuming they are O rings, a good hardware store should have them. If it’s some other kind of seal, get the model number of the filter and us Professor Google.dennis 221 said:After removing it,when u reinstall strainer do u lube the rubber gasket? If so with what,Vaseline ect. Also where can I purchase new rubber gaskets for it.
