Fielding.dots
My inside cold water connection to the shower failed on my 2006 Kestrel(hawk).
Anyone know how these plumbing connections work? I can't figure out what is wrong and how to fix.
The brass elbow goes into a white plastic nut, inside that plastic nut is a rubber collar and a metal flange. The elbow slides into the plastic nut with the rubber and metal gasket and gets tightened.
When I turn the pump on the metal elbow for the water line gets shot out due to the pressure and the nut and gaskets are not holding it in.
