leadsled9,
Sorry I took so long to respond but I've been out playing in the desert.
I mounted the meter on the cabinet next to the 12vdc outlet. I then wired it to the outlet switch. The only thing I use the outlet for is running a small inverter to charge batteries and this hasn't damaged the meter. Normally I leave the switch in the off position. Now that I know these meters are sensitive to voltage spikes I'll be careful what I plug in there.
Thanks camelracer. You've given me an idea. The stock set up from FWC on my Hawk has a panel monitor, with a small momentary switch that needs to be held down to turn on, which displays the water level and the level of charge. Do you (or anyone else) see any problems with mounting the meter there? I could wire it so the meter would only work while holding down that switch.
Another point. I see that the meter in question is also offered in a model that takes a maximum of 45 volts, as opposed to the maximum of 25 volts models I've seen in this thread. It might prove to be more robust.
