Jacks Question
The first question is whether they would mount properly on the camper’s existing corner brackets. I suspect they would from looking at the manual, but don’t actually know.
The second question is whether that mounting method would space the jacks wide enough that you have adequate clearance to the truck sides to allow a little maneuvering as you back your truck under the camper. If you have an HD truck it won’t be adequate. A half ton or a Tundra might clear. You would want to measure this for your truck. My GMC 3500 hd needed extension brackets in the front for the fenders to clear with some margin. The rear jacks just use the Reico welded plate with no extensions.
Thanks Jon. I have an ‘06 Tundra access cab with a Hawk on it currently. We used a friends jacks to get it on but I’m hoping to buy the c-clamp model used for a seller nearby. Thanks for your help.
The Rieco-Titans on my 2001 Hawk are the c-ring ones. Those came with it. I used them to load the camper onto my older (2001) F150 by bolting them directly to the camper's jack brackets.
When I replaced the F-150 with a 2013 Tundra, I added 1/4" aluminum extension plates. I don't quite remember whether I HAD to have the plates or just wanted additional clearance.
Note: My Hawk has the older jack brackets (the one-piece, 14", five-hole ones) but I believe the jacks should also work with the newer brackets (the two-piece, 13", three-hole ones). (And I see the ones in the manual are the newer style two-piece ones.)
Edited 10/31/22 to add:
Update:
This morning I noticed the manual shows different part numbers for jack brackets for fixed versus c-ring jacks. Does that mean the c-ring jacks ONLY work with the brackets with the c-ring part number? Or will they work with either?
So I called Rieco-Titan Products in Frankfort, Illinois. According to customer service agent 'Sue', the c-ring jacks will work with either bracket. The different part numbers have to do with the type of hardware included with the bracket ordered under those numbers.
And if you do happen to want a quick-release jack system, consider this...
cvant's post in "Quick removal camper jacks?" thread
Note that cvant thoughtfully included attachments with drawings with dimensions and provided part numbers for the shoulder screws and nylon locking nuts. That info could be taken to a fabrication shop.
Well done, cvant!
(also- see the entire thread for other ideas to speed up jack removal)
