MikeDahlager
I found a website which has 12v LED light bulbs for sale. <http://tweetys.com/starlight-led-bulbs.aspx> I think I will replace all of the incandescent bulbs in my camper with these as the incandescents draw a lot of power and produce a lot of heat. One good thing about some of these replacement bulbs is that they produce a light similar to incandescent bulbs, not the cold blue light of other LEDs. Mind you, this is only a preliminary search and there are probably less expensive sources.
I mentioned in an earlier post that I purchased a roll of LEDs and intended to use in Elk camp. <http://www.coolerguys.com/ledstrip.html> I ordered the HT 60 LED Double Density 39 inch Long Flexible Light Strip 12 volt White 6500K for $18.95 Well, it worked great except the color (6500K) was blue white and not that warm incandescent hue. I have since mounted it inside the shell of my truck using the same connector the camper uses. I can now sort my gear during late night and early morning fishing trips without having to use a flashlight.
Mike
Mike
