LEDs Make the Big Time
Jack
Nov 18, 2007
427
Portland OR
LEDs have finally become a true alternative to 12v incandescent lights. We just got and have been using the new LEDs from https://www.superbrightleds.com/other_bulbs.htm and they are fantastic. The light is 3600K, which means more natural light than the standard incandescent bulbs. They are about 2/3rds the brightness, but plenty bright enough for reading, even with our aged eyes.
LED Price
$22 + $5 shipping, be sure to select the warm white, 3600K LEDs.
LEDs slowly fade over time - figure 3 to 5 years.
These LEDs draw about 190mA. There is a 36 LED module that draws 120mA, but it is 7000K, which means a much more blue light. We got one of those and will replace one of the higher power modules if we are planning on camping for a long period of time without a "recharge opportunity" (ie, driving to somewhere else).
And why do we love to go where most people don't - have a look at the chanterels, girole, pfiferlinge - name your language, we'll pick'em, eat'em and oh, so, enjoy them. We got them in N. CA on our last trip north (no, of course we won't tell you just where!).
Securing the LED's
I am also interested in knowing how they were secured. I tried silicone and duct tape, but neither lasted more than a couple of days. On the other hand, is it necessary to secure them? Mine now are resting down on the light cover but since they don't get hot, doesn't seem like that is a problem.
I got the 36 leds and they are great......cheap insurance no melted walls or fire hazzards. I also replaced the doublesided tape with a stronger 3m tape works great.....
I have these two and the bluer ones. They work well for me. I used some double-stick tape to secure them.
They just sit on the cover
Because LEDs run cool, I just let them sit on the cover. Double sticky tape seems a good solution, too.
be careful on which method you use to secure them. I used some kind of caulking/silicon not sure and it corroded the pcb which caused some of the leds to fail. All it takes is a little silicon or velcro to get it to stick. also note which direction you mount th lights. straight down is good but you can also angle the pcb to get light more where you may want it.
leds are great. im thinking about adding a small red led reading light for bed reading.
$22 +
Come up to Oregon. They're everywhere in the woods.
Bob
Has anyone seen what FWC has up their sleeve for LED lighting? Tom mentioned it when I was talking to him at the Phoenix Sportsman's Expo, but didn't know when they would be bringing them out and I didn't think to ask him about the possibility of retrofitting them.
They are a direct replacement for the bulbs in our fwc's. Same socket but with a 1.5 inch by 1.5 inch square filled with 36LED's. The back of the square has a double sided sticky tape that sticks to the metal on the original light fixture. More info here http://jclampstand.com/
Jim
I just installed 4 of the AC 36-AB LED cards. I am happy with the way they shine.
Jim
It looks like you already had the fluorescent system before this install. Big difference?
I had the standard incandescent 2 bulb light fixtures. It isn't brighter but uses alot less power and will not melt anything.
Jim
Sure looks a lot brighter than the current led pack i have (and that failed). Might have to try one.
Do you or anyone else know how these LEDs compare to the FWC/ATC fluorescent lights?
Mike
EDIT:
Never mind, I forgot my wife HATES fluorescent lights! :eek:
Guess who would be in the dog house behind the camper!!
So, off researching LEDs............
I found some very interesting info about LEDs http://blog.rv.net/2008/03/09/whats-new-in-rv-illumination/
Also, unlike ballasts, in fluorescent light fixture, there is no R.F. (radio frequency) interference.
Recreational vehicle interior lights have not yet seen these superior lamps. When they do, they will offer a host of benefits. In ceiling lighting applications, where dimming may be desired, the L.E.D.s maintain the same color throughout all settings, unlike the yellowing out that we are used to with current light fixtures.
Mike
