Thanks Vic
Ya it is a pita. My two panels, one on roof 160 and one portable flex 100, are in parallel. Is it as simple as changing the plug on one to the opposite? (Plus minus) ... that is ... using a reverse male to female adapter. Or do I need to do some fancy rewriting?
I only use the flex panel when it is cloudier... so series would make more sense. In series the bolts are then additive say 9v on one and 8 v on the other if end up with 17v?
