CPT Davenport
Is 100AH lithium enough storage to keep 85L 2 way fridge and camper running? I will be running 200w panels.
Cpt Davenport said:These are all good numbers and stats, thanks you guys. I originally was going to mount 2 of my rigid 100w panels. I think now that I will buy the Renogy 175 semiflex panel and start with that and a folding panel as a back up. I purchased a 100ah Relion lithium battery, but need to build the rest of my system. Here is what I think I need so far. Please let me know if I'm missing something or should look at other options or variations.
1. Relion 100ah lithium
2. Renogy 175w panel
3. Victron 12/12 30 DC-DC (ISOLATED OR NON ISOLATED?)
4. Victron MPPT charge controller (ANY SUGGESTIONS ON WHICH MODEL?)
I need help with fuse types, sizing and locations.
Do I just get an adapter to go from the SAE to MC4?
I go mostly with circuit breakers, as discussed below. Powerwerx sells Eaton-Busssman switchable circuit breakers which are half the price of Blue Sea, and appear to be identical. They were sold out of the one I needed a month ago, but the salesman revealed that they have an in-house brand which appears identical, and was even a bit cheaper. Talking in person to their sales staff was really great; they are eager to please.Cpt Davenport said:Thanks for the reply Charlie. I just ordered the 100/20 charge controller and the non-isolated 12/12-30 DC/DC unit. I think this set up will meet my needs and power demands.
Anyone with advice on fuse type, location and sizes for these units?
That’s what I thought. I have a fair knowledge of electrical but not enough to just dive in without some guidance. Thanks for getting back to me and confirming what I was thinking!I misunderstood what you were describing. Disconnecting the ground from the ACR prevents the ACR from closing to connect the truck battery positive to the camper battery positive. I thought you meant you had disconnected the main negative connection between the truck and the camper.
With your clarification, I think what are doing is an acceptable, safe way to accomplish what you are trying to do.
Thanks for sharing your experience with heated battery. I think I would probably get by without the heated. I will most likely only camp in the snow a few times and then I have the heater to keep the battery above cut off.Our lithium battery (SOK) has a heater which we've only needed once. It was below freezing for about a week, and down to 17F at night. But it didn't seem to work. It's energized by the charger, not the battery itself, so our 100W solar panel wasn't enough to heat it. But it also didn't heat while driving, which was disappointing. Good thing it only cost $10 more than the non-heating version. We still haven't sorted out what's wrong -- where we live it rarely gets below freezing.
