Loud fault noise when unplugging shore
Fielding.dots
Sep 12, 2019
21
Oakland, California
Hello,
I have a 2006 FWC Kestrel.
When I unplug from shore power I get a loud and long (3-5 seconds) beep. Sounds like a much louder and sustained version of the fault beeps for low battery.
I've tried researching this and have come up with nothing.
Anyone have any ideas what this could be? I assume this is not supposed to happen.
All my electrical works on 120v or 12v. I have the fridge and freezer combo, solar panels and the camper connected to the truck battery (per FWC).
Thank you!
Could it be your propane / CO sensor losing power? They should not lose power when you unplug from shore power, but I do know some of then beep when they loose power. There are just not many devices on an FWC that know how to beep.
Hello
Have you tried turning off the 120 power supply with the breaker in the truck before pulling the plug on the shore power connector.
Russ
It's my LPI gas leak detector located below my fridge. When I turn of my main kill switch or unplug from shore it beeps fault/low voltage. In assuming this isn't an issue, unless it's telling me there is a fault somewhere.
