I searched here and posted on FB. I just returned from a month long trip. I used my inside stove more than ever. I usually only use one burner for coffee in the morning. I cook outside with my Partner Steel. This trip because of lateness into camps and in-climate weather we used the inside stove for meals for all 3 of us traveling together.
Issue: I discovered that the left burner on my Dometic flat top has no power? It lights but no adjustment and at low levels. As suggested on FB I checked ports for cleanliness and such. All looks good. I will try anything recommended before contacting FWC for fix. The other burner works fine. My dealer here, where purchased, has closed and no other FWC dealer is in close proximity.
I guess I could take to any RV repair place? However, it may be cheaper to just replace than that
