The statement about a 10 gauge wire having one ohm resistance per thousand feet raises questions about what load, voltage, and temperature? Furthermore, it is my impression, that the 7 pin connector circuit uses 14 gauge wire.
I didn't make that statement and usually go on voltage drop charts for a given current in a wire size personally. When dealing with batteries when you start loosing a few percent voltage it makes a difference.
The stock wiring on a 7 pin is likely something smaller like 14ga so if one was planning to use the stock 7 pin many resources recommend running a new heavier gauge line. The housing can be rewired for heavier gauge.
Regarding mechanical switches, they require some degree of human attention. As we know, people make mistakes that can result in either discharging both batteries simultaneously or accidentally disconnecting the alternator from both batteries, possibly damaging the alternator.
No arguments here.
We are not addressing the shore power charging system here, but it adds an additional complication. Shore power systems are much better than they once were, but they may be challenged with the same old problem of charging two batteries at the same time.
Well now we're jumping out of the original discussion but there are numerous battery chargers out their with dual (or triple) leads so each battery gets its own charge.
About costs; Delco use to make very good 60 amp alternators with internal regulators that could be purchased rebuilt from Autozone for about $25 each. The mounting brackets are the most expensive part of the dual alternator system. A standard Delco alternator provides regulated power through a single wire.
Yeah a rebuilt altenator is cheap but I'm guessing the mass of folks aren't going to be able to design a reliable mounting bracket that fits somewhere into a modern engine bay in a place that allows it to be tied into the belt system while still allowing all the other components to operate properly. With that in mind we're stuck with kit pricing when discussing the costs of a mass implementation suggestion.
To balance against this, there are costs with a single alternator system that have not been addressed. For example, if a vehicle is disabled on the White Rim Trail, wrecker services to retrieve it will exceed $1000. All things being equal, a dual alternator system is at least 4 times as reliable as a single alternator system. How much is the greater reliability worth?
The discussion is wandering here. Granted there are external issues that can be factored in but you can't just make the statement a dual alternator is the cheapest solution at face value.
***All that said I am a fan of them and I'd encourage anyone interested that has the money and vehicle to accommodate one to pursue if they want one. Just trying to clear up some statements which I considered to have been painted a tad broad at first.
