Mojave Preserve trip part #1
lqhikers
May 18, 2007
594
la quinta calif
Just got back from a trip to the Mojave Preserve with my wife and thought we would share trip and pictures.The first part of trip was covering a part of the Mojave road which follows an historic Indian trail/wagon road/stage route from near bullhead city Az. to Barstow off I-15 (road to Vegas) We just did a section near Kelso (neat restored train station now Preserve information center/Museum,a must stop for first time visitors.2nd pic is mine area and 3rd camp spot ,a good place to explore and get the feel of the area. Next, 4th is Marl springs which was a important water spot and army post (1867).
I,ll post pics then continue.
Les Lqhikers
Mojave trip continued
Marl springs,(2 pics)Mail box(1 pic) which is a stopping place now to sign in and take a break.A little past here we took off on side trip to cinder cones lava beds to explore one of the lava tubes/caves.Set up camp here to explore caves and hike to lava arch which is an old Indian area with a lot of rock art etc.
Les lqhikers
Mojave trip continues
Lava tubes/caves hard to get good pics but do show size and vents.
Les lqhikers
Mojave trip continues.
more lava tubes .This area is always great to explore as you will always find something new and it is not over run with people,we did not run across anyone on any trail the whole week we were in area,must be the price of gas!
This is the lava arch area.Lots of Indian traces in area and if you are willing to hike you can find some interesting spots that are not disturbed!Make sure you have your boots on as the lava is unforgiving!
Mojave trip continues(Providence mtn.area)
After exploring Lava area we headed back to Kelso and used their good history section to look up a couple of mines we have heard about but do not show up on newer maps.1st pic is of the Good Hope Mine you have to do some research as the trail is through a wash and is not visable .but with gps setting from map's we were able to find mine.A lot of old stuff and if you hike the canyons you can find a lot of shafts that are not on maps!(no off road travel is allowed so it is hiking only.
Mojave trip Continiues
I could spend days in these old mines as it is unbelievable what it took to work them (supplies,water equipt etc.) Fund so old corner markers with claims and left them for next person to find.Seems like anything next to a road is long gone so it is nice to find some old paper work.
On to next Mojave MIne!
After we spent 2 days at the Good Hope mine we moved about 5 miles to the end of trail that stops at the wilderness boundry.This mine is hard to find without gps and even then it took 5 hours of hiking up the mtn trails to find,But was it worth it! Since the trail up the wash was washed out for 3 miles the was no trail to let anyone know their was a trail ahead.As you can see from pics if the structure did not fall down it would of been untouched since the early 1950's.We almost turned around not 100 ft from mine as we thought the shaft in first pic was it but over the ridge was the main mine.This mine is near the Tough Nut Spring Which you can find on some of the maps of the Providence mtns.We still can't figure out the two hole out house
More Mojave mine pics
more of mine area,lucky the fire that burned this area a couple of years ago stopped just on other side of canyon!
More mine pics
Hope you all don't mind so many pics,explains better than words,at least my words!
A few more of Mojave trip
Three more for now and i will finish up trip report soon.Hope you all enjoyed.
Drive slow and enjoy "its the journey"
Les Lqhikers
Just amazing what is out there in the desert. How people could make a living with all that hard work. Thanks for sharing.
Thanks for sharing. I'm up in that area every month or so for work... maybe I'll have to bring the truck on one of my trips up there to do some exploring. hmm...
:thumb: on the pics!
I had to cancel a planned trip to Mojave last Fall. Seeing these pics doesn't make me feel any better about that decision....:(
Wonderful pics, what a beautiful area. Your outfit looks right at home out there.
lq, a quick semi off-topic question. With your roof rack and additional weight on the roof, have you devised a tool or anything to assist you in popping and lowering the top? Or do you just use the good old 'arm-strong' method?
answer to kcowyo
If you make a trip to Mojave Preserve make sure to visit the depot as it has lots of great info on area,including library with old maps etc,you could spend days going over books maps etc.I had a basic lift device that worked ok until i saw one made by star152 which gave me a reason to make new one,which is what i use now,works great even wife can use it.If you look at pic on link you will see a 2 wheel pulley,which i have now replaced with 3 wheel pulley,only because i found one at a swap meet for $1.00! Hope this helps you out.
http://ww w.wanderthewest.com/forum/showthread.php?t=986
Les Lqhikers
Mojave trip final spots on trip.
When you are at Kelso (train depot) if you look up to the providence mtn,s there is a spring called cornfield springs,about 6+miles up wash/canyon/rocky ground all the way.This was where the water supply came from to supply steam trains that ran through here.What make this remarkable is that the supply system was built around 1895! when you follow this line and see what they had to do to run this line (buried most of way,exposed in canyons)its hard to believe how it was done!The pics show spring which was expanded by blasting down through rock to improve flow then cemented to keep clear.You can drive to with in 1 mile.(trail is washed out,could be done if you had more than 1 rig would not do it by myself!)also some great canyons to explore,again no people and it looks like their had not been any for a long time.We hiked up road/trail then returned along pipe line through canyon.
Les Lqhikers
Last Mojave report!
This is last spot we wanted to find.We had heard of a spot that was used as a water supply spot for the Tough Nut Mine,after finding spring on map we used gps to get to area,no trails all washed out over the years as this spring is in a steep wash area.This one was hand dug lined with railroad ties the first 25 feet our so then lined with rock at water level,still not caved in and water still flowing!also spot was used as a ore crusher (small crusher) then hauled out by mule or? As there is also surface seepage it also had sighs of lots of wildlife using(deer,bobcat,couger,sheep tracks.all in one spot!)This is also in wilderness are so it is hike in only! this is the end of Mojave trip,already planing next!Maybe we will run across fellow fwc/atc travelers!(somehow i missed pic of well itself)
Les Lqhikers
