Looking for opinions, experience, and generally whether you think the following is a good deal or not.
I have the opportunity to buy the following TC/Truck package from the original owners for a sale tag of: $14,000.
What would you do?
2000 GMC Sierra 2500 (3 door extended cab)
4WD
Long Bed
Vortex 6.0L, 4 spd auto trans with OD
Tranny Cooling System
Engine Oil Cooler
Autotrac Transfer Case
Locking Rear Differential
Off Road Skid Plate
Wiring for camper/5th wheel
HD Trailering equipment
Trailering/Handling Suspension package
OEM rims and tires
Westin Running Bars
Truck has 30,399 original miles on it (not a typo)
I had the truck inspected by my mechanic and his only notes were the following:
Bump stops cracked
Tires weathered
AC needs recharge
It also has mounted in the back the following:
2000 8.5' Timberline "pop up" camper by Lite-Craft (Colorado)
3 way domestic fridge w/freezer
atwood 3 burner propane stove
6 gun suburban water heater
16,000 BTU forced air furnace/thermostat
3 layer insulated softball
20 lb propane
Power Convertor
Thetford cassette toilet with 17L holding tank
30 gln water tank
Inside shower
Queen bed
4 mechanical jacks (Titan)
Fan-Tastic Air Vent\
Scissor Steps
I currently own a 2006 Chevy Silverado
Vortex 6.0L V8 Gas Engine
just turned 100k miles
It is in good condition with the usual bumps n bruises for a 10 year old truck
New tranny 2 years (8k miles) ago
Standard Bed
Running Bars
Oversize Tires / Rims (Would swap with 2000 GMC)
So my predicament is this:
Should I buy the TC/Truck package and sell my truck to cover the cost after swapping the rims and tires and brand new (less than 1000 miles) Bilstein Shocks.
I figure I could get around 17k for my truck as it is.
I tried to add pictures for reference, don't think it worked
Thanks for any response.
Scott
What would you do?
4WD
Long Bed
Engine Oil Cooler
Off Road Skid Plate
OEM rims and tires
Westin Running Bars
Bump stops cracked
Tires weathered
AC needs recharge
20 lb propane
Power Convertor
30 gln water tank
Inside shower
Queen bed
Scissor Steps
Standard Bed
Running Bars
Scott
