New ATC shell build
jasona
Oct 5, 2016
46
Lake Tahoe
Picked this new girl up about 2 months ago from ATC. I finally got her all together and looking good. I'll put some more photos up on the build and put a few how tos together once I get back from camping!
RenderedContent-3B6073A5-FFB3-466F-96BD-86B6806665EB.JPGRenderedContent-939E8654-D97D-40B1-BA8A-175F8731E621.JPGRenderedContent-8D0E72EC-8D20-4957-A4D0-FCF24AC676DC.JPGRenderedContent-C3269D15-F0D2-4FD7-9A3D-89D16487789C.JPG
Propane box is a air tight box made by a white water rafting company out of Idaho. I mounted a retaining ring to hold the a standard 20lb tank. I like the idea of a 20lb take for easy late night exchanges at gas station when necessary. I also mounted my regulator in the box and ran a copper line out the bottom using a 3/8 through hull fitting. To vent the tank I used a 2in abs shower drain and run it down using flexible pvc pipe and out the bottom where the truck overhangs the bed rail. CAC21ACD-CBC7-460F-AFB8-153ACF7E33B7.jpeg85F27CEB-0179-429D-B35B-B27A058C747C.jpeg
I used a propex 2800 heater in my last build and loved it. To mount it I used two large L brackets and secured it using webbing and clips. D38D1B20-B69F-48DB-ACDE-E6A247118B56.jpeg
I ran the intake and exhaust vents Under the propane box and out the wall using propex through hull fitting. I came up a little short on tubing and had to drop an extra 100 bucks on the stainless steel tubing (ouch). D168590D-C1B1-4383-8C22-065A828F82C8.jpeg95485FD7-3D10-41E4-905E-83C4EBCC8574.jpeg
I supprised myself with the innovation on this boot dryer, not to toot my own horn. I started with a 2 in tee to split the ducting (sorry no pic it’s buried under the heater). I used a 3 in shop vac attachment to regulate the flow to the boot dryers.D07B3DF6-05C7-480A-B398-10678C6D7EA3.jpeg
Reduced the size using a 3in to 2 3/8 silicone boot to fit the 2in abs pipe. Built the dryer out of 2in abs and used a hose clamp and small chain to secure it.9B9028AF-7AEC-4582-9EA3-40F22F065724.jpeg
When not in use it stows away nicely under the cabinet made by ATC and swivels out for drying boot and gloves. B5B9C88F-ADC4-4AF0-ABE4-F6406CBD6138.jpeg
I found that all the flow was going to the last of the four vents on the boot dryer so I put a small amount of expanding foam in them and then removed it slowly after it dried to get a desired flow.
I spend 6 weeks in Alaska in March and April snowboarding and dry boots and gloves are a must have in the morning for me. I’ll post some more of my build in the next few days.
Cool idea with the propex heater and boot dryer. Betting a lot of folks on here could use something like that.
Nice camper.
L couch storage and fold out bed.
Counter/table combo
