New Hawk Shell on Order - Advice needed :)
ianpatrick10
Dec 14, 2022
2
Hey Everyone,
I'm a Nor Cal native and just ordered a new Hawk Shell model. I lived and sailed for years on a 46' sailboat I completely restored. I am new to the camper world after years of camping in the back of my pickup in the shell. I am super stoked to join the FWC community and would appreciate any wisdom you can offer with regard to setup. I'm trying to do this on a budget so I ordered the Shell version with the intention of up fitting myself. My main questions are about which furnace specifically to order, which hot water heater and freshwater tank and maybe any other advice I might need going forward.
Thanks so much in advance!
Ian
No hard rules or designs. What ever works for you and gets the job done. Check out some of the camper tours on YouTube and pictures/videos posted on this website. Lots of great info on electrical/solar and plumbing installs. You will find many of us use marine grade components that you might already be familiar with(blue seas, anchor, jabsco, etc.). Some people here are minimalist campers and others want all the bells and whistles, to each their own.
ianpatrick10 said:
… I'm trying to do this on a budget so I ordered the Shell version with the intention of up fitting myself. My main questions are about which furnace specifically to order, which hot water heater and freshwater tank and maybe any other advice I might need going forward.
Ian
Since you are trying to minimize cost, one thing I’d suggest reading forums and thinking about is whether you really want a water heater. Being a backpacker, I would be satisfied with heating water on a stove for washing dishes, and using a hanging shower bag with water warmed on the stove.
Howdy
And welcome to WTW. We have enjoyed a FWC shell model for many years.
Are you trying to decide what items to have the factory install ?
David Graves
When I bought my Shell Model Ranger II back in 1998, I had FWC include the large kithen cabinet and countertop but without any of the appliances (stove, sink, fridge, water heater, water tank etc). They turned the small sliding door under the counter into a large sliding door which allowed me two large spaces to put my food on one side and my kitchen bag (REI camp cook kit, plates and utinsils) and Coleman Stove on the other. I also had them make the side bed for me which allowed storage for long things under it. I strapped down a porta potty in the aisle on the floor below the front window. I used a 5 gallon water jug, but down it Baja I bought the 5 gal. jugs of purified water and used a hand pump. This worked for me for many two to three month Baja trips.
I use a lot of small stuff sacks to keep things organized and they fit into large box like cabinets more effieciently than building cubby holes for individual items.
We purchased a compact stove/sink combo (https://pantherrvproducts.com/mo8821lus/)
because we wanted to be able to just make coffee and brush teeth and this does the job in minimal space. It is spendy, but does the job in minimal space on top of the furnace box and worth every cent.
The key that makes it easy for a DIYer is that the propane manifold for your furnace has an extra port (see pic below). So I only had to add a 24 inch propane hose to hook it up.
And I'd agree with Jon R on the water heater- not worth the added complexity if you have a stove to heat water, but that is a personal choice -- everyone has different needs and camping styles. I have more detail on this and other simple components in our Hawk shell here (https://sites.google.com/view/sagebrushers/home).
Best of luck!
IMG_20190423_105002069 (2) Stove-sink installed.jpgIMG_20210902_144806010 (2).jpgIMG_20190322_111935284 (3) manifold with extra LP port.jpg
i also bought a shell (ATC ocelot). and intended to install the propane tank, with access thru the outside door (had atc put the door in). but after using the shell for a couple yrs, i decided the internal propane storage would just take up too much space. we only intermittently cook inside, and i have a robust Partner cookstove that can work inside and out.
i installed a propex propane furnace in december and really like its small footprint, and it is pretty quiet. i cut a hole in the original propane access door, and use that to exhaust the furnace. i bought a propane bottle bracket from AT overland, and it bolts to the rear jack bracket. i put a hole thru the rear wall, and pass the propane line thru it, and to the furnace. works great. again, i am not a huge winter camper, and did not want to use limited camper internal space for things i use only periodically.
good luck - i have found that camping with the shell greatly increased my thoughts about what i need, and dont :) .
go
Latest posts
