JeffWright
- Joined
- Aug 13, 2016
- Messages
- 34
Hi guys, I just went on my first trip with my new Lagun table setup. Nothing too exciting about it working as a great table for the rollover couch on my ATC bobcat. But what I think is really cool is that I mounted in a position where I can raise it to the same height as my countertop. Originally I was going to bolt the mount through the frame and outside of the camper but decided to use screws into the frame and then plywood to attach the mount. Partly because I didn't want to take the camper off of my truck and also because I really didn't feel like putting more holes into the side of the camper.
![IMG_4263-2.JPG IMG_4263-2.JPG](https://www.wanderthewest.com/data/attachments/23/23425-429558a5bd19d34ca50cf4beac55f136.jpg)
My only change might be raising the existing mount slightly and then adding another mount directly below. The existing setup is great but is at the max end of the height when it's fully raised and then at the complete opposite end of the spectrum (almost too high in the column to clamp on to the mount) when its in table mode.
I also put a mount on my Jerry can holder: Originally I wanted to put it on the side near my propane tank where I can add a T and another line for my portable stove but couldn't pass up the ease of install on the jerry holder. The camper is also made for a little bit smaller of a truck and I'd have had to use a giant spacer to clear the where the sides flare out on the bed.
![IMG_3714.JPG IMG_3714.JPG](https://www.wanderthewest.com/data/attachments/23/23427-b72e316bbf1caaeb39ac2d3a0eec5f0f.jpg)
![IMG_3713.JPG IMG_3713.JPG](https://www.wanderthewest.com/data/attachments/23/23426-8d291f0ea2dda23a51c5403659bfcb80.jpg)
