No 120V Power to My Power Panel
Are the outlets on your camper GFCI outlets, and if so, do they need to be reset? Press the test/rest buttons on the outlets and I am guessing they will work.
For the fridge power, pull the fridge 12V fuse and see if the fridge still runs?
If you push your silver plug in and the fridge is still running then it's running on AC. All the other breakers should be in the on position except the breaker for the converter which should be off unless shore power is plugged in. This is to prevent a surge when actually plugging in to shore power.
