Norcold refrigerator removal
Chukar Hunter
Dec 17, 2007
146
Virginia City Nevada
I've been searching the files looking for how to remove the Norcold from my 2007 Hawk but not finding any information
I need to pull it out just far inough to get to the back of the switch panel and install a wire kit that is supposed to be the fix for it not staying lit on propane mode
Any of you guru's have suggestions or have installed this fix?
Thanks in advance
Rich
Mine is the Dometic, but can't imagine it being much different. Mine has 6 or 7 screws around the front flange. Mine has trim around the door opening that needs removed to access the screws. There are two screw tabs on the back that are accessed through the outside service panel. Mine requires undoing the propane and 12v lines, then it slides forward into the camper pretty easily. Somewhere on here Mark BC did a write up on swapping his 3 way out for a D.C. Fridge. IIRC, it was pretty detailed with photos on both removal and install. Finding it may help.
Good Luck....
