riz
I've got an older OLYMPIAN catalytic heater that I'm not using much anymore. It's the 8100A model which is now called the Wave 8, the larger of the three current models. This heater will heat a large camper or motor home no problem. I've used it to heat my garage a few times. It's not in perfect shape... The pad has some wear, and the starter doesn't work. It lights up fine with a match and heats well. I'd like to get $200 shipped. Winter is just around the corner... Heat your rig silently with no drain on your battery!
http://smg.photobucket.com/albums/1003/rizart/?action=view¤t=0e56b820.jpg&evt=user_media_share
