SunMan
King Taco
After much research I finally pulled the trigger on an Olympian Wave 3 heater as my camper did not come equipped with a furnace.
Attached are some pics of the install:
1. I had a custom hose made at a local propane shop and connected it to the propane line in my ice box cabinet (now a pantry).
2 & 3. I cut holes thru the cabinet into the outside storage box.
4. Then cut a hole into the camper.
5. I had extra hose made so that i could put the heater up on the counter top should the lower bed ever be used.
6. Final install.
The hose is now neatly routed and held in place with oversized conduit straps so the extra hose will slide when pulled. All in all I'm very stoked to finally have "plumbed" heating in the camper. I was tired of messing with those propane canisters and my portable heater. It is completely silent and seems to heat things up pretty fast but i still need to field test it. Also need to get a CO detector installed.
6. Final install.
