Argonaut20
- Joined
- May 24, 2009
- Messages
- 432
When storing I set the camper on a platform and run the jacks down to the ground for stability. We've had 60 - 70 mph winds and the camper is still there. I do like Leadsled's trailer idea so the camper could be moved easily. I still would lower the jacks, though.
As for solar, I bought 2 plug sets (male and female) and installed one female connector on the under side of the ledge over the truck bed. The controller is near the entry for the cord. I made up a 20 foot extension cord from 14 gauge wire that rides in front of the camper in the truck bed. I made a mount for a 40 watt panel that puts the panel over the truck cab. When traveling I have the panel literally bolted into the mount. When it is charging time, I take the panel out of the mount, hook it up to the extension cord, and put the panel in the sun while the truck is in the shade. You can do a larger panel (as Barko said, prices are coming down) and put together a system pretty reasonably when you have the cash and time.
