lmwilco1
I have 2 Rich Solar 160W solar panels mounted flat on the roof of my Grandby connected in parallel and feeding my Renogy DCC50S charge controller. Since I ran the batteries down testing the fridge install I was watching the charge current coming in from the solar. Conditions today are sunny, and 80 degrees. I was getting 8A of charge current as measured by the Vectron battery monitor. I never did much testing when I installed the system in the camper so I decided to cover each panel in turn and measure the current to verify both were working correctly, When I covered the first panel I got 2A of charging current, when I moved the cover to the second panel I got 1.8A of charge current. I was expecting to see roughly 4A of charge current from each panel resulting in the 8A total that am measuring when both panels are uncovered.
Any idea why I only get ~2A per panel when one is covered but 8A when neither is covered?
Louis
Louis
