We are picking up our Hawk base model in 2 months and putting it on a new F250 Tremor. Super excited about the camping upgrade. I have a few questions about things I should address day 1 or prior to pickup. I've posed these same questions to my salesperson, but appreciate this community's feedback.
For context, our FWC is a base model, open floorplan, 135A lithium, Truma heater, king bed, quilted thermal, roof tracks, and will have the new bamboo countertop and coin flooring. I will be building a lower bed for our 3-year old son out of 80/20 and mount our Dometic fridge in the camper either under his bed or on one of the shelves. Also plan on adding either a torklift glow step or an easy hitch step to get in.
- Mounting on an F250 - The other thread has me a little concerned about mounting using regular eyebolts on our aluminum bed F250. Has anyone come up with a tie-down structure/bracket that uses factory tie-down locations? If not, I'll at least be adding some aluminum plate on the underside of the bed to distribute the pulling forces over a larger area.
- Solar - have a 200w panel to go on top. Does FWC still use the SAE plug on the roof? Just need to know if I need to buy a MC4 to SAE connector.
- Are there any wiring "chases" in FWC's on the exterior walls? I want to add some perimeter lighting using Baja Designs S2's, mounted directly to the exterior and with a switch inside the camper to turn them on.
- "Must have" upgrades. Anything you all have added that FWC does not provide and you swear by?
