Silvertip47
The Chair Bandit
OK .... thinkin this over, I ended up getting a 86 CJ5 Jeep, inline 6, and 5 speed. I figured this is probably the way to go, a little larger, a little heavier, but no trailer, it's street legal, someone sees the jeep or camper parked on the side of the road ...... they're thinking, "he's hiking and due back any minute". So now I just make camp and hop in the Jeep and off I go ...... back road or paved road.
Now I open the "can of worms". I thought, I could just flat tow it, put the trans and transfer case in neutral, make sure hubs are turned out, hook up the lights and tow bar, and it's "on the road baby". Now in searching the Internet I'm getting all sorts of horror stories. Don't "flat tow", disconnect the drive lines, only trailer it. So, I value your opinions. What's your thought's? "Life is not easy here in the West".
Thanks,
Funstini
I would venture a guess that Jeeps are the most towed 4 down vehicle there is. I know a lot of Jeeps differ from each other in order to tow them. I would find a good Jeep mechanic, maybe at a 4X4 center and get the low down for your specific Jeep. I know that rear wheel locking hubs are available for a lot of Jeeps. That, with the front hubs would eliminate all drive train movement. Might be the way to go.
I just called a good friend of mine down at Bucks 4X4 Center here in Boise. He said your Jeep does need the drive line removed to flat tow. However, Warn does make the rear locking hub for your Jeep. Then, locked out, nothing in the drive train is spinning but the wheels and perfectly safe to flat tow. Hope this helps.
Thanks,
Funstini
