Portable Reverse Osmosis
coloradoclimber97
Jan 16, 2018
35
Does any one know of a salt water capable portable reverse osmosis water purifier? I sailed with a guy from Florida to the Bahamas a couple of years ago and I swear he had such a device, but can't seem to find anything when I search online.
I have a trip planned to Baja this winter with an eye toward destinations further south eventually and would love to not have to worry about water (particularly south of Mexico).
Thanks,
Mark
Just google water maker. There are lots of them out there in the marine world. They are expensive, as with all marine hardware.
Thanks everyone, the links provided were exactly what I was looking for. I had no idea that ROs where that expensive and finicky - looks like I need to find another solution.
Internet search for "Solar Still".
Tons of information out there on the web.
If you are going to be staying at one location all day or multiple days, a solar still can help with fresh water production. If not staying put, then I'm sure you can come up with something on the back or roof of the camper.
The Aquamate Solar Still is commercially produced and similar to what naval aviators (back in the day) carried in a pant leg pocket of their flight suit, except a smaller version. Works both floating and on land. The Aquamate can create clean water between 0.5L & 2.0L per day. depending on conditions.
For the home made solar still (sort of fun for kids to build) can look like this (from the How to Make a Solar Still)...
It can be a science kit for the kids.
Water from the ground is the dirty water source, even works in the dry desert, although water production is lower..
Here's a web link to the Aquamate Solar Still Deluxe Water Purification Kit (non-floating - simpler) for those that want to purchase it that way.
For personal use I carry my home made version; a sheet of plastic (get a new one each year) and this cereal bowl as the clean water collector with molded in straw which I connect to a clear aquarium tubing of about 4 feet in length. The plastic folds up and fits inside the cereal bowl along with the tubing. Light weight and small. I practice my solar building skill at least once or twice a year. Just keep everything, the plastic, the water collector and the tubing clean.
There are many other types of solar stills. A long time ago I had a home made hard side one that folded up to a flat unit like the size of our common rigid solar electrical generation panels. Carried it on the roof of my old Bronco. Made a couple of gallons of fresh water each day when I was in Baja.
It's just sun light, dirty water, evaporation and a clean water collector.
Thanks Alley-Kat. Very informative stuff. Now how do I scale up a solar still to make it practical without taking up so much space in my FWC that I need a trailer.
I have built and used Solar stills in semi arid environments as part of survival training courses. 1) You really need something that contains water in the pit under the plastic. 2) It takes several hours to produce just a little water. 3) They are annoyingly slow and inefficient.
It would take more energy to speed the process up (more area with more solar irradiance or an alternative heat source). Lots of people have put some thought into this but I suppose they could have overlooked something or missed an application specific opportunity (e.g. using waste heat from some other process).
https://www.researchgate.net/post/How_we_can_enhan (e.g. use waste heat from something ewlsece_the_performance_of_simple_solar_distiller
