donks2
Hi All,
Gathering my equipment for my solar install on my older NOT pre wired Hawk. I would like to be able to use a portable panel along with the 180w Grape panel I've put on the roof. What kind of port have you used? The Zamp seem better due to 10AWG copper wire, but there is the reversed wiring to correct. Seems most of the others use 12 AWG aluminum wire. Both types seem to have the weak link of the cover 'leash' breaking. Are there other choices out there that I'm missing?
I'm also thinking I'll wire it so the panels are in parallel, but I'm open to thoughts on this.
BTW, I'll be running it all through a Victron MPPT
Thanks for your thoughts!
