After getting back from a couple weeks of hunting and camping I decided I needed to get an idea how much power my camper uses. I have a three way fridge in my camper. I have installed LED lights in the sockets. My camper does not have a heater. I do have a Buddy heater (no power) and I have a small electric heater when I am plugged into the generator or shore power.
My camper power use.
The camper with the switch pulled and fridge on Gas mode 270 to 288 watts / 2.3 amps
The test below is the same as above but with lights
1 light 300 to 311 / 2.4 amps
2 lights 318 to 325 / 2.5 amps
3 lights 325 to 328 / 2.6 amps
4 lights 330 to 339 / 2.7 amps
5 lights 343 to 348 / 2.8 amps
This test is with the comfort zone heater
https://www.amazon.com/Comfort-Zone-Personal-Heater-CZ707/dp/B0007ULR14/ref=sr_1_21?s=home-garden&ie=UTF8&qid=1477435575&sr=1-21&keywords=comfort+zone+heater
The camper switch is pulled and the fridge is on.
Heater on low over night setting. The heater comes on and turns off with thermostat .
1025 watts / 8.5 amps when heater is putting out heat. Actual watts used just for heater is 737 watts on low.
The camper switch on, and fridge on. Heater on high MAX 1527 watts, 12.6 amps.
Actual power use when heater is on high is 1239 watts just for the heater.
I know I can't run the electric heater with my battery. How much solar would I need to just keep the camper going with the usage I have?
