longhorn1
Ouch, that stings!
I decided to use the gray coating to paint the bottoms and sides of the cross slats on the bottom of our 2014 Grandby. This is the area that comes into contact with the bed of the truck. I was kinda shocked to find numerous bare spots on the bottom that never got painted in the factory. My jack leg bases severly rusted in less than 6 months. I wired brush and primed and will put a finish coat on when it warms up. Should that have happened? I also found 5-7 staple pops where the staple was not driven level into the floor, but instead driven at a angle popping out part of the plywood bottom on the underside of the camper. I wonder how much that compromises the structural integrity of the lower side and floor. Should additional staples be added around the bad ones? You thoughts!!
