I am in a quandary on my keystone/granby - Cougar rebuild. To catch up see here http://www.wanderthewest.com/forum/showthread.php?t=632
I bought an 08 and now after I had the base already rebuild and the camper sided it won't fit the new truck.
1st question - Do you guys see the value in the step design of the base. My thought was to build it up square at the 4 foot width and just attach the step up to the outside. That way if I do change pickups again I won't have to redo the base again. I think this option would only add a small amount of weight over the original step design. The only issue would be I wouldn't have the free and clear access that one has with the OEM step design.
2nd question - The older campers didn't have as much head clearance as the new ones do if I understand it right. I am 5'11" and fit ok but some of my taller friends that will hunt with me are over 6' and they will have to duck down. I didn't think I was going to replace the canvas so I just bought new lift panels. Now after I got the new panels in, I worked with the old canvas and decided to dump it and get new. When I had it rebuilt I had them add @ 3" to it so I could get better "overlap" for water protection. Now I have the option to add a little height to it but that would require another rebuild to the lift panels. What do you think, raise it up? Leave it as is and forget that I had the option now?
I have pretty much used the camper for a shelf in the garage over the summer but should get started rebuilding it again if its going to be ready for hunting season or next years camping season for that matter.
