On our Alaskan trip I had to use the heater a few times. Usually just in the morning.
I would switch the thermostat on ,the fan would start than the gas/flame would cycle on and off but not stay on to provide heat.
After messing with the temp setting it would finally stay on until the temp was reached than shut off like normal.
I could hear the gas igniter click,light the gas than after a few seconds it would shut off only to click and ignite again.
Is this a thermostat problem and I should replace the manual one with a digital one.
Or is there something wrong with the gas/valve/igniter?
After say a few minutes messing with the thermostat the heater would run great and crank out the heat.
Any ideas would be helpful.
