Gormley Green
Contributors
Last night I noticed my rear "porch" light (the orange one) won't turn on. The bulb appears to be fine and it worked the day before. Is it on the same fuse as the exterior lights? If so, the fuse is fine. The wire insulation has worn slightly as it was rubbing on a screw in the housing (maybe 2mm exposed). Looks like it should work though. Switch still goes click, but no light.
Any thoughts?
Any thoughts?
