longhorn1
Ouch, that stings!
So I got the fan and mounting brackets from FWC. I attached the wires behind the refer to the fan, red to blue and black to black for the ground.I removed the rocker panel and located the wires behind the panel. Both of those wire are blue. How do I tell which is the ground or does it matter??
I tried to push the new rocker switch into the panel opening, thinking it would snap in. Afraid to break it but maybe I just need to push harder.
I have everything open I could use a little help.
Thanks,
jd
Thanks,
jd
