Jack
While I love Victron stuff, when I replaced my old Nasa BM-1 battery monitor, I went with the $73 Ali battery monitor (same as the Renogy at $96). I'm a glutton for numbers and the Ali displays everything: Ah, SoC%, V, A, W and time left. The victron gives me 1 number and an SoC bar graph.
The Drok "battery monitor", below the Ali, measures camper load with a hall effect sensor on the wire to the 12V shut-off switch.
The Renogy/Ali has a 500A shunt but my typical max current is 30A or 6% of the shunt so I was concerned about accuracy. Compared with my LiFePO4 battery BMS, the Ali is almost always within 1% - but I'm almost always above 80% SoC. The lowest I've gotten was 66% and it was within 1% of SoC. Volts tracks with BMS within the approximately 3.5 digits of precision, as do the MPPT charge controller and Drok BM. Different sampling intervals make amps harder to compare as the current draw (fan, refrigerator, cell/pc charging) even at night varies slightly over a few seconds.
Pressing the top << button for 2 seconds toggles the light on/off. If on, the screen dims every second or so when charging.
