alano
Got this email this morning...
Dear Valued Renogy Customer,
You are receiving this email as our records indicate that you have purchased a product with the model number RNG-100DB after April 28th, 2015.
RNG is issuing a voluntary product recall of specific 100 Watt Renogy bendable solar panels. This product is being voluntarily recalled because the configuration of the product may cause it to overheat, posing a fire hazard to consumers.
Serial Numbers Affected:
The products are 100 Watt Renogy bendable solar panels with the model number RNG-100DB. The products have the UPC code 720825342283 and a serial number beginning with 15029201504030xxx or 15037201504140xxx.
Participating in the Recall:
Please stop using this product immediately. You can return your unit for a full refund or a replacement product.
Kinda steamed by the whole thing. I bought two flexibles, glued them to roof and had them fail. Scraped them off the roof, returned them for replacements, designed and built a new "above the roof" mounting system for them and now I'm looking at doing it all over for heavy panels. Looks like I'll be looking at roof-lifting shocky things too now.
Deep breath... I already have one rigid panel mounting up top that I got when I didn't realize the first two flexibles were failing. Maybe the answer is to swap one flexible for a rigid and take the refund for the other and go back to 200W. From a cash point of view I might be able to just about break even including the lifters.
Alan
- If you return your unit for a refund, a pre-paid return label will be sent to your email address. Once the product has arrived at RNG’s location, a full refund will be issued.
- You may also replace your unit with a RNG-100D rigid panel and receive a partial credit. A pre-paid return label will be sent to your email address. Once the product arrives at RNG’s location, a partial refund will be issued.
Alan
