Replace, Upgrade, or Repair Norcold Fridge/Freezer?
foakes
Mar 24, 2019
25
Sierra Nevadas of California
Hi Everyone —
Thank You for allowing me to join the WtW Forum & Website.
I have a 2002 Toyota Tacoma with a 2002 T100S Six-Pac camper.
Bought the truck and camper new in 2002.
3.4 V6, 5 Spd, 4X4, SR5, TRD, etc..
Upgrades are 1-Ton leaf springs, upgraded front coils, upgraded shocks, suspension air bags with under hood compressor, Michelin ATX AT2 in 10 ply “E” rating for up to 80 lbs, 8K Warn winch, ARB front bumper, Bluetooth Sound, and a few other things.
Here is my question for the experienced experts:
I have always had trouble when running the 300 Norcold Fridge/Freezer on LP. Either won’t stay lit, goes out, hard starting, unreliable, now the gauge is not working that shows the LP operating range. Works fine on AC power.
We are going on a 2 week trip through the Southwest the first half of May.
So should I try and repair the fridge for the 4th time, replace it, or is there a better upgrade that I can look at installing?
Maybe a 2-Way, instead of a 3-Way (we never use the 12V because it drains the battery too quickly)?
Appreciate some advice and direction...
Thanks in advance!
Best,
Fred
Also, we only use the camper for perhaps 7 to 10 days a year.
And, I can post pics of the rig and the fridge — if someone could coach me in how to post photos.
Best,
Fred
well, after 16,17 years I guess it doesn't owe you anything. can't recommend a replacement tho personally, I'd look at Nova Kool, but for my own reasons. so why am I posting ??
curious about cost of parts your model, this was my first search hit
https://thenorcoldguy.com/norcold-n300-n302-parts/?sort=featured&page=2
on page 2 I saw this with a number of good reviews
https://thenorcoldguy.com/norcold-wire-kit-628119-when-the-refrigerator-wont-stay-lit-fits-n300-3163/
I admit it's only a 1/2 cent answer that you may already have known ...
Good luck with it
and welcome !
You may be able to clean the fuel jet as they do tend to get what looks like a calcium build-up. I did this with the first fridge in our first camper. A year later it needed it again and its performance wasn't all that great to start with, so I put a compressor fridge in and never looked back. The new camper ironically has the exact same Dometic 3 way in it. I haven't bothered trying to see if it works or not. Next weekend's project is to install the same model Indel compressor fridge as the last camper got.
Being very careful to level the fridge is very important, the flame needs to go straight up the pipe on my old six-pac i was able to access and clean the pipes from the outside on a small ladder. Buy a small good level.
When we had a 3-way I placed a circular bubble level inside the lower access opening for the fridge. I didn't care if the camper was level or not, I cared if the shelf that the fridge was sitting on was level. I also bought one of the remote fridge temperature monitors so that we could monitor the temp from the cab. Best that we ever got was 40° below ambient.
I don't have a fridge so may not be the best person to comment. Nevertheless..
- If the fridge is in relatively good condition physically and you have the time and inclination to mess with it, I'd see what videos there are on YouTube to try to repair the existing fridge... or at least troubleshoot it. This Norcold N300.3 Diagnostics video, for example. It's a little confusing (and maybe a bit intimidating) but has some good info and includes a list of things to check in the comments area:
"Typical problems are dirty burner, misaligned thermocouple, thermocouple failure, interrupter, excess resistance in wiring and switch between terminals of the interrupter".
Other possible resources-
- Dirty burner
- LP Mode troubleshooting bulletin
- N300 Service Manual
Also- I see the Norcold Guy links provided by klahanie in post #3 include a wire kit 628119 which reportedly addresses won't-stay-lit issues (presumably this refers to the excess-resistance issue).
- As to swapping out for a two-way, I probably wouldn't do that for the limited amount of time you use the camper each year and the fact that your Six Pac's standard electrical system probably wouldn't do well with it...at least not if it's still the original design. That assumes, of course, that you're happy with the performance of the propane fridge when it does work.
Start with cleaning the burner, I always blow it off with compressed air to clean mine. Take a look at the flame, if it doesn't look correct (size, and color), performance will be degraded. Most times it seems to be either small rust flakes or dust/cobwebs etc that affects performance. As mention above, being level(very) is a requirement for max performance. You are correct in that most propane fridges will see a max of 40 -45 degrees below ambient temp. Be sure the wind shield is in place to prevent flame blow out.
If the camper is wired to safely support the monster !12 VDC amperage draw of a 3-Way fridge then it is over-wired to support the amperage draw of a compressor fridge.
Our 2008 Norcold stopped working. I had learned to clean the jets to keep it running.
But, temp control was irregular and we lost veggies when they got frozen which isn't great in the middle of a desert trip.
I did my research to find a compatible match, to fit the previous unit and went with a Dometic compressor 'fridge.
I was able to plug in the bayonet 12v FWC wiring harness without issues. It works for us, with our 120A solar and 100AH battery.
Agreed. I shouldn't have said 'your Six Pac's electrical system' when what I meant was the overall design of the battery charging system of both truck and camper. Sorry about that!
Since Fred doesn't mention solar, I assume he doesn't have it. According to this Six Pac manual, the standard setup is to charge the house battery via a connection between the truck's seven-pin trailer plug and a corresponding seven-pin plug on the front of the camper. Given the Tacoma alternator's relatively low charging voltage (probably mid-13's), the relatively small wiring between truck and camper, and the long wiring run, I'd think the house battery wouldn't be recharging very quickly .... perhaps not quickly enough to support furnace, (compressor) fridge, lights, etc. And therefore he'd be forced into some overnights at shore-power-equipped campsites to recharge (or carry a generator).
I guess the question is what else Fred might need to consider when he's thinking of swapping out his three-way for a compressor fridge given his current battery-charging setup.
2x-same sort of story as Lighthawk! Kept my 3-way alive for years including living thru it shutting down a couple of times out in the boonies , when I one time I was camping with Steve P up at the Virgin Springs CG on the Sheldon NWR in Nevada, when "boom" it shut down again. I did a TR on what happened next several year ago called "when things almost when boom" or something like that (put ref in here later), anyway lost a bunch of lamb chops but made it back to my RV place in Susanville. To make long story short-I had been planning to convert over to solar anyway -and this gave me the physical reason to do so. Yep, a second house battery, an another 100w solar panel,, new comptroller and a $1700 dometic CR compression frig/freezer later I was solar :oops: . Have not looked back since, so use your experience to improve your WTWing experience!
Smoke
Update: "When things almost went boom!" posted 19 May, 2014! (sorry still don't know how to put ref in here to make it easy to post :oops:!
Thanks again, everyone —
Here is where we are as of today:
New same model Norcold 3-Way costs about $850, shipped.
Took everyone’s advice — pulled out the current Norcold N300.3 fridge (easy, as you said).
Found a couple of pounds of mud wasp and paper wasp nests hanging from the interior cabinet, above the controls, and wiring.
Some of the mud was fused tightly around the dial controls where the wires attach.
Cleaned out cabinet and wiring and top of fridge.
Also, the tiny gauge blue insulated wire that goes to the flame indicator on the front top of the fridge control array — was broken in two.
The flame chimney is rusty, as well as the flame tube inside the pilot box.
So — I will purchase a new fridge, if no reasonable fix makes sense.
However, if I was able to diagnose the various issues as to voltage, LP, etc. — I would like to try and repair this one.
My only hesitations would be — going over $300. Since at that point, I would likely be better off with paying the extra for a new unit.
I do have a 100W solar panel that is on the unit — but it is basic, and has never worked since it was installed.
Would just like to get back to a factory operating unit, or better — without any complex fixes.
Can someone help me post pics?
Best,
Fred
I think what I will do now —
Is clean the fridge of all exterior debris —
Check all wires — replace any broken — strip back ends — solder new connectors on — clean the bayonet connectors with a Dremel — spray electrical contact cleaner on the ends —
Remove the flame chimney — burn tube — clean them outside and inside with a wire brush chucked in a drill —
Adjust the igniter to proper depth —
Install new insulation on the chimney —
Reinstall the fridge — connect 12V, LP, plug in 120VAC —
See if there’s any improvement in LP operation —
If back to 100% —good.
If there are still issues — address those and/or decide what to do next...
Best,
Fred
Old Crow said:
Agreed. ......
Ah! I see what you were driving at. Yes I agree, given those conditions & constraints the system probably can't recover what is used by a compressor fridge very easily.
Solar: It would be worthwhile to get that working regardless of what fridge you opt for. There's lots of info posted here and folks with experience who can help.
Just got some great help from Old Crow on posting pics —
So will do that tomorrow —
In the meantime, I think I posted this thread in the wrong category, unknowingly — should likely be under 4 wheel campers, or?
Could a Mod or Admin please move it to a proper category?
Thanks!
Best,
Fred
Just a heads up, for anyone interested...
Being a Moderator on another outdoor sports equipment site — it is disappointing when folks come on a site just to get info — then never give the folks who helped a report...
I will post results on the fridge in a few days, or less.
Took advice on here from some of you experts — since a new fridge is about $850 shipped, best price — I decided to attempt a repair.
The top of the fridge was impacted with wasp and yellow jacket nests, and one small wire to the flame indicator gauge was separated.
Removed fridge, cleaned up everything, cleaned with a wire wheel the burner, and chimney. Ultrasonically cleaned the orifice and supply fittings. Cleaned up the thermocouple. Reinsulated the chimney stack. Replaced the two stage gas regulator.
Starts well immediately — runs for maybe 10 minutes with a great blue flame — then cuts off.
Ordered a wire set that is supposed to help or eliminate this issue, from the Norcold Guy, for $19 plus shipping — supposed to arrive today. Should be a simple pull out the fridge maybe 8” — install the wires, clean the bayonet connector tabs — then see what works.
Still may need to replace the fridge — but I am thinking we are much closer than we were a couple of weeks ago.
I do have photos of the processes so far, and will post them when the solution is completed — however it turns out.
Thanks again for all the help...Stay tuned!
Best,
Fred
The (2) wires ordered from the Norcold guy — did not solve the problem of the fridge staying lit while on LP.
Ordered a new thermocouple, along with an interrupter.
Hopefully they will get here soon. The wires took 6 days to get here from the same state I live in, California.
Wires — $25 shipped
Regulator — $30
Interrupter & Thermocouple $80 shipped
Question:
How is the voltage measured with a volt meter set to Millivolts — when there is no access to the top of the fridge when the fridge is installed? The fridge cannot be pulled out of the cabinet when the LP line is connected since it is copper and not flexible.
Do I need to rig up a separate LP tank, connections, 12V connections to bench test the volts? Or??
Hopefully, with these 4 items replaced that run about $135 — the fridge will work on LP.
Best,
Fred
Here is where we are so far — a FYI to all who have helped, Thank You!
Pulled out fridge, have it on the bench with an LP tank connected.
All gas parts have been cleaned to shiny, inside and out.
All electrical wire ends have been cleaned or replaced.
Chimney cleaned, Burner tube, orifice, cleaned ultrasonically.
Replaced regulator at LP tank.
Replaced the wires recommended by Norcold Guy.
Replaced the thermocouple.
Replaced the interrupter.
Replaced the selector switch.
All parts are Norcold — except regulator, which is an exact to the original, however.
Starts immediately, runs for 3-4 minutes, good blue flame, thermocouple in the flame, starts to cool, then flame just goes out. Starts again on first snap of piezo — goes for 1 minute — then flame goes out.
No sign of Ammonia leak in cooling unit — runs perfectly on A/C or D/C — just not LP gas. Switched to another full 5 gallon LP tank — same exact result — no good.
Gone through troubleshooting steps in factory service manual, not owners manual — multiple times.
Can’t figure this out...
Call & Email into “Norcold Guy” — no response yet, been 2 days. Called and left another message today.
Any ideas?
Frustrated as to the next steps.
Best Always,
Fred
Latest posts
