Jamesiam
A small Dilemma.
Installing a Rich Solar Mega 200 Watt 12 V panel with a Solar Panel Connectivity Reverse Adapter.
With the MC4 to SAE plugged in Polarity is in fact reversed.
I have to attach the SAE to SAE that will correct this issue, but it does not supply enough clearance with where I want to install the panel. East to West in between the front and rear fans.
I also don't want to go higher as the space between the panel and the roof is already too high for my comfort.
Can I simply connect the red to the - and the black to the + on the PVM side of the Victron charge controller?
