Has anyone installed one of these in your ATC or FWC?
https://www.customcylindersintinc.com/store/roof-jenie
Frank, if you're referring to the Rieco-Titan electric lift, yes, it's possible for the roof to be stuck in the up position or part-way down due to an electrical problem. The lift can reportedly be operated 'manually' in that case with a flexible shaft you chuck into a drill motor and put into each actuator motor to turn it to lower the roof. However, I've not yet been able to find anything that says this backup system actually works in practice. Yes, the actuators have that feature but it's not clear to me that the camper manufacturers leave room for the drill motor and shaft to be fitted into place.Casa Escarlata Robles Too said:Do you think lowering the roof on the FWC/ATC would be a problem?
Sure would save the back.
I'll stick with the roof lifters.
They have worked for 9 years now don't see a change coming.
