Roof Weight on a FWC???
remithoren
Aug 29, 2007
32
Thanx for good tidings on our trip to New Orleans. Still waiting on the whether to choose the route...And I certainly agree that the Tundra looks and drives better with the FWC. I pulled that bigfoot x country twice and don't miss towing. That is the major reason we went for the FWC!
For more storage I put my thule roof box on top (to bring back XMAS stuff) and I had a helluva time pushing the top up. This is without any weight in the box. Not sure if I should bother taking it along. I seem to recall others have dealt with this. Stan or Ben any comments on static roof weight?
Other questions for the Stan/Ben team. Where exactly is that solar prewire and when did you make it available?
thanx to all,
Jeff aka Rem
2006 Hawk
2005 Tundra
Roof Box
Putting a pod on top can be heavy. The roof will take it but as you have found out, it's a matter of how much can you push up. The best location for that heavy an item is in the middle of the roof on one side or the other so that you divide the weight from front to back. That will make it eaiser to push up. You still might have to unpack it though.
As to the solar wire, on your model you will have to ask Stan. I don't know where they put them on that year.
Hello Jeff aka Rem
They started pre-wiring for solar in the middle of 2005, but for a few months it was off and on.
I believe in early 2006 they started pre-wiring for all campers on a consistant basis.
If you know your camper serial number, or the date of manf. for your camper, or want to e-mail me your name if you bought the camper new (or the original owners name), I can pull the original production file and see what notes are in there. There could be some measurements for the location on the roof. That is how we are doing it these days to make it easier for customers.
My direct e-mail address is ... stan@fourwh.com
If your camper is older that a 2005, most likey the roof will not be pre-wired for solar.
You can also do a quick camper check and peak behind the front wooden lift panel (cab-over bed area) - usually drivers side.
There are normally 2 wires tucked back there that run from the cabinets, along the frame, up behind the front lift panel, and up into the roof to supply the interior lights with power, and also power for the powered roof vent fan(s).
These wires are normally Yellow & Black.
If the camper was pre-wired for solar you will usually see a total of 4 wires back there (Yellow & Black for lights) and also (Red and Black for the solar panel pre-wire).
Hope this helps.
... Where exactly is that solar prewire and when did you make it available?
Jeff aka Rem
2006 Hawk
2005 Tundra
We usually recommend 200 - 300 lbs. of weight on the roof max for gear.
Less weight is always better, as you have found out.
The more weight up there, the harder it gets to lift the roof.
There are also a few threads on the forums about this topic for "list assist devices".
These seem to help for the times you have gear on the roof and can't easily take it off before you pop the camper top up.
Here is one sample thread ...
http://www.wanderthewest.com/forum/showthread.php?t=986&highlight=%22lift+assist%22&page=2
remithoren said:
... I put my thule roof box on top (to bring back XMAS stuff) and I had a helluva time pushing the top up. This is without any weight in the box. Not sure if I should bother taking it along. I seem to recall others have dealt with this. Any comments on static roof weight?
I traveled to Alaska with a Thule box plus two 5.5 gal gas cans up top for over 3 months with a bad back. I used a small foam pad on top of my head for the back lift and because I have support across the front about 2 feet high used the flat of my back to lift the front. It isn't that huge of a problem getting the top up and have never had any problem. I will say my roof sags a little when the box is full of ski stuff in the winter and I grunt it up.
Roof weight
We have a long thule box on top, too. We really like it to store lightweight extras and keep the camper clear for dealing with kids (changing diapers etc), eating lunch, and spot for the dog on long trips. What we've done that might help you is (if you have the yakima track system) is space the mounting holes further apart on the box to better-distribute the weight to the front and back of the camper. Our box is really old so we don't care too much about changing/compromising it's design. Just keep the gear as light as possible. Don't risk injury, though. You might consider a hitch cargo tray instead.
good luck,
Marc
ha ha
Sometimes we tie her to the hood, too.
for clarification,
"keep the camper clear . . . for a spot for the dog (on the lower bed with cab window open)." NOT in the Thule box. :eek:
Dog carrier
I think you are on to something there. Drill a few ventilation holes, throw in a bowl of water and the dog will have a great view of the journey. I think there might be a market there for that one.:)
My dog loves riding in the truck, most do. Its just real interesting to see the expression change when he realizes "hey, we left the city, those are pine trees, oh boy!, we're going camping".
