banderswipe
Hi All, I echo Rusty's advice, "Kid Gloves" when loading or unloading the camper. The number one rule always put the camper on level ground preferably concrete. Number 2 always have someone guide you back into or pulling away from the camper.If you touch any part of the camper when backing in or out you run the risk of twisting your jack plates and allowing momentum to twist your jack legs through 90 degrees and dumping your camper either on its roof or just pancaked on the ground,believe me. I loaded mine on my own and just touched the side of the camper,it started falling back wards away from my truck it twisted all three of my jack plates and ended up teetering half on half off the bed of my truck. I lifted it up at the rear with a Farm (Jack-all) jack straightened out all the jack plates with some gentle swearing and brute force,backed under it again only this time with the farm jack at the back of the camper to prevent it from going back wards again.
This time I was successful and the rest they say is History or learning the hard way.I am going to replace all of my jack plates 3 of them and add a fourth and have them on the corners. I Will put my farm jack behind and have some body to guide me as well next time.
I wish somebody had given me this advice before I loaded my camper. I was a hairs breadth away from dumping my camper on its roof,you should have seen the air around me it was blue and not from the color of the sky.
This story might be entertaining now but it wasn't at the time.
If you experienced guys have any advice or story's on this topic dont be shy make us laugh or make us cry or add some new rules.
Thanks,
Kevin. (still a NOO PS you can see in the pictures that my jack plates are still twisted.
Thanks,
